Passing Lamp Socket, Tool, Thingy!!!
Received 2,530 Likes
Received 3,988 Likes
Fuel injection line sockets also....but I had a hard time finding a 9/16 one. I thought some of the older diesels had 9/16 nuts on the fuel lines... I found a 14mm which is close.
I ended up using my 4" grinder with a cutting wheel to make one out of a cheap 9/16 deep well.
I bought a cheap 9/16 six point deep well socket. Was planning to cut a slot as recommended above. Now I am considering taking the cut all the way to the bottom of the socket, making it sort of a pass through socket with a slot. Then turn it with vise grips rather than a socket wrench. This way the socket will not twist the wire.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
