Headlamp trim ring fitment
Has anybody fitted the headlamp trim ring to their Road King Classic (part # 69627-99)?
Apart from being a fiddly job, when fitted over the OEM trim ring (as per instructions) there is an ugly gap between the headlamp lense and the back of the new trim ring, ranging from 1/8" at the top to 1/4" at the sides and bottom. The pic in the shiny bits catalogue does not show this gap. Any suggestions or is this just the way it is?
Cheers,
Chris.
Cheers,
Chris.
I was aware of the gap at the bottom. Because of previous dead horses. But until I installed it, I wasn't aware of the gap between the rear of the trim ring and the lense. Looks like crap, but not unless you look closely. I guess I never looked that close before. I'm going to be checking out everyone elses now. Beat that horse!!!!!
Cheers,
Chris.
Cheers,
Chris.
try installing the new ring without the old one. you fill have to fill the space around the headlight with door seal tape (the stuff you buy at any hardware store to keep drafts out). just wrap the tape around several times, try fitting the new ring, if too lose, wrap some more tape until fitment is good. if you search on this topic, you'll find this same remedy has worked for many with no gaps anywhere.
