oil drain plug
Old 06-24-2009 | 11:39 AM
pbscm28's Avatar
pbscm28
1st Gear
Default oil drain plug
anyone cross thread or have an issue with the motor oil drain plug on an '07 street glide, i have a slight drip on mine after changing my own oil, i have already drained the oil again, replaced the o ring and re tourqued the plug but it is still at a slight drip. looking for feedback on oversized plugs or any solution. Thanks
Old 06-24-2009 | 12:05 PM
JustDennis's Avatar
JustDennis
On my 96 RK, I always used a new oring and a little teflon tape on the threads. If I didn't use the tape, I would get a little leak like you described
Old 06-24-2009 | 12:29 PM
ndnguyd's Avatar
ndnguyd
+1 on teflon tape on all three plugs.......
Old 06-24-2009 | 01:18 PM
UALCapt's Avatar
UALCapt
Oversize (thicker) O-ring (avail at auto or hardware stores) will solve your problem.
Old 06-24-2009 | 01:42 PM
HDSAE60's Avatar
HDSAE60
the teflon works good for me
Old 06-28-2009 | 08:28 PM
pbscm28's Avatar
pbscm28
1st Gear
Thumbs up oil drain plug
I was thinking teflon tape, thanks, another hog marking its spot
Old 06-28-2009 | 08:39 PM
cruise_carter's Avatar
cruise_carter
Permatex makes a thread sealer with teflon, works excellent and I use it on all drain plugs. won't tear like tape
Old 06-28-2009 | 08:44 PM
emwolb's Avatar
emwolb
i've gotten in the habit of using the teflon tape, and once you figure out how to roll it into the threads you'll like it. i know, the o ring is supposed to seal, but i use the tape for added insurance. and it also will prevent the threads from seizing. just my thoughts.
Old 06-28-2009 | 09:30 PM
Neckball's Avatar
Neckball
No thread sealer or teflon tape for me. Still using the o-ring the factory installed, 67,000+ miles later, no leaks.
Old 06-28-2009 | 10:11 PM
Bingo's Avatar
Bingo
Rub some oil on the O ring before re installing, same as you do with the rubber seal on the oil filter.
I would be afraid of torn pieces of tape getting in the engine, but that's just me.
Quick Reply: oil drain plug
