American Rider-Riding baggers over 4,500 RPM
Old 08-10-2009, 09:21 AM
emwolb's Avatar
emwolb
emwolb is offline
the only time mine has seen 5,000 rpm is when i get to an onramp and want to impress myself. other than that, we bee croozin, at 2500 to 3000.
  #62
Old 08-10-2009, 09:45 AM
HDRider2002's Avatar
HDRider2002
HDRider2002 is offline
I'm like the rest of you guys, 3000-3200 tops then i shift. If i get above that, its typically during a downshift for passing, or maybe pushing through the gears while feeding my need for speed.
  #63
Old 08-10-2009, 09:57 AM
beary's Avatar
beary
beary is offline
Here is a question and maybe this isn't the thread to ask, but when stuck on the highway (65 to 80 mph) in 100 degree Oklahoma heat, what RPM range cools the engine best?
Beary
  #64
Old 08-10-2009, 11:25 AM
genedjr's Avatar
genedjr
genedjr is offline
03RK - so no tach, but...
For cruising I use 5th from 45 on up.
For passing it depends on the amount of room, the winds, current speed, ect. But the 03RK really likes 70+ in 3rd, 80+ in 4th and 100+ in 5th.
I really like the autometer combo. But the cost puts it a bit lower on my priority list.
...gene
Attached Thumbnails American Rider-Riding baggers over 4,500 RPM-autometer.jpg
  #65
Old 08-10-2009, 11:37 AM
jimsflh's Avatar
jimsflh
jimsflh is offline
Originally Posted by TheShrink
Black on tach is for Harley and red is for me. I hate that 6200 wall! These Rinehearts love to make noise from 3500 all the way to 6200.
With a stage one (air cleaner upgrade) you can easilly raise that wall to 6500 or a touch higher, and instantly add a few horses too.
  #66
Old 08-10-2009, 11:43 AM
piasspj's Avatar
piasspj
piasspj is offline
Damn, I thought the only usless gear on my '08 was 6th. Guess 5th is a waste as well.
I may try staying in 4th a few rides and see what happens.
  #67
Old 08-10-2009, 12:18 PM
RTBrandy's Avatar
RTBrandy
RTBrandy is offline
This is a great thread! I usually ride between 2800-3200 but maybe I should be riding a little higher...Will have to [seriusly] try it out...
  #68
Old 08-10-2009, 02:36 PM
skratch's Avatar
skratch
skratch is offline
Received 4,365 Likes on 2,540 Posts
i didn't read that as having to stay in that rpm range all the time but that there would be more power available when needed going into that range. i don't picture anyone running through town at a constant 4500. around here, that would keep me in first gear.
if i'm just cruising, i'll keep it around 3k - 3200 range, but i definitely let it go higher than that when shifting through the gears, especially if i'm trying to get somewhere in a hurry.
  #69
Old 08-10-2009, 02:40 PM
gunner11's Avatar
gunner11
gunner11 is offline
2800-3200, most all the time.
  #70
Old 08-10-2009, 02:53 PM
RThomas4223's Avatar
RThomas4223
RThomas4223 is offline
I have an 02 EGC w/95" engine & 203 cams. I generally shift at 3,500 RPM. When I have to get it on, I've had it to 4,200 a few (very few) times, & only one time to 4,500 RPM.
When I'm solo, I "cruise" at 2300 RPM or better. With my bags loaded or 2-up, it's 2,500 or better. My engine's "sweet spot" is 2,600-2,800 RPM which, with the stock 5-spd, is 60 MPH or a little better. At that speed, except in the twisties, I can enjoy the scenery.
Ride safely! [or, if you are inclined, "Ride fast and unsafely." - your choice.]
Quick Reply: American Rider-Riding baggers over 4,500 RPM
