American Rider-Riding baggers over 4,500 RPM
Old 06-23-2009, 05:30 PM
IslandGlide's Avatar
IslandGlide
IslandGlide is offline
I usually cruise at 3000. Hit the limiter lots pre Stage 1, but not since. Regular shifts are 4000-4500. I feel that 3000 area is the best cruising rpm for the bike. My test was to find a straight flat stretch, put on the countdown to empty timer, and check remaining kms at about 115 km/h (70mph) in 5th gear around 3000 rpm, then maintain the same speed in 6th around 2600-2700. I've found it gave a higher number of remaining kms in 5th at the higher rpm. Result=more torque on hand and better fuel mileage...a no brainer in my unscientific test!
  #52
Old 06-24-2009, 02:40 PM
screamin_willy's Avatar
screamin_willy
screamin_willy is offline
Ride it like you stole it, 3k or above for me.
  #53
Old 06-24-2009, 03:07 PM
NoBoldRider's Avatar
NoBoldRider
NoBoldRider is offline
Originally Posted by maineultraclassic
Anyone who has ever looked at a dyno sheet will know what Joe Minton is talking about. The HP at 5000rpm is going to be a lot more then at 2500rpm, therefore you will have a lot more pulling power.
My normal cruising range is around 2500rpm, but if I need to get up and go...........drop 2 gears and get those RPMs up and let her rip. Nothing like hitting the rev-limiter in 3rd gear at 90mph!!
Steve
Since HP is only the result of a formula with inputs of torque and RPM, HP will always be higher as RPMs go up, at least until torque drops way off. Your best RPM range would be whereever your peak torque is found. That being said, you would problably find youself somewhat above that range when passing on the freeway or running from the highway patrol.
  #54
Old 06-24-2009, 03:25 PM
tremor's Avatar
tremor
tremor is offline
So I've been testing this theory for the past couple of days and while it takes some getting used to (not shifting at the start of the whine), I do believe that I'm getting more out of each gear and the bike certainly feels happier/snappier at the top end.
Thanks for the lesson.
  #55
Old 06-25-2009, 08:56 PM
Ram's Avatar
Ram
Ram is offline
Originally Posted by xxxflhrci
No tach and don't need one. I ride by feel and with my ears. If I can tell she's lugging, I down shift. If I want to make a power move from going slow to moving fast, I drop a gear or two as needed. If I am trying to move fast, I let the seat of my pants tell me when to upshift. As long as she's pulling, I hold out for the next gear. Sure, you might hit the rev limiter every rare occassion. No big deal. It won't hurt it.....I pretty much thought anyone that operates a manual shift vehicle did the same thing.
Very well said.
  #56
Old 06-25-2009, 10:00 PM
iclick's Avatar
iclick
iclick is offline
Originally Posted by mhud
I'd be curious to hear what range my fellow baggers ride in?
I'm at 2000-4000 rpm 99% of the time.
  #57
Old 08-10-2009, 08:05 AM
checkers's Avatar
checkers
checkers is offline
these twin cams like rpm's more then previous engines. they dont like to be lugged. it is important for longevity of motor to keep rpms above 2200. remember t/c 's run extreme lean below 2200 and if run above that gets more fuel for cooling etc
  #58
Old 08-10-2009, 08:19 AM
Mike5959's Avatar
Mike5959
Mike5959 is offline
I am usually running at 4500.... then again I ride like an aHole and love to hear my exhaus.t
  #59
Old 08-10-2009, 08:59 AM
The Old Man's Avatar
The Old Man
The Old Man is offline
I find that if I keep her at about 2200 rpm in 4th gear around town that equals about 45 mph. Did that for a tank full. Kept shifting at about 2400 and run around like that I got 44 mpg!!
  #60
Old 08-10-2009, 09:10 AM
beary's Avatar
beary
beary is offline
I rode a lot better without a tach on my RKC than I do with my SG. I had no trouble cruising 80mph on that 88 egnine in high RPMs, but I seem focused to much on the Tach of the SG. So I will start riding by the seat of the pants again, except when I follow that Honda with strait pipes.
Lucky for me I broke my SG in at 4500 to 5000 rpms for a few runs.
Beary
Quick Reply: American Rider-Riding baggers over 4,500 RPM
