Hey, how long are you guys running the HD Synthetic Oil between changes? I put HD Syn. in the primary, engine and trans. Have 2500 miles and was gonna change the engine oil. Should I do the primary and trans. as well, or can they run a while longer. Just looking for opinions.
There are a bunch of threads on this, I run 5K on the eng oil and change out the primary and trans every other eng oil change. I'm running amsoil in all 3 holes.
I do the same, 5000 engine and 10000 tran and prim, using syn3 but switching to amsoil
My local dealer recommends not to push the 5000 mile service even with the syn oil. So I change just my oil at 2500 and do the full service @ 5000. Unless you ride less than 2500, change it each yr. I am sure others have other ideas.....Just my 2cents.
I run amzoil and go 3-4K and tranny has belray. haven't changed it for about 25k hate draining a fluid that looks the same comming out as it did going in.
I have been using SyN3 since it came out, and changing to Amsoil, put the 20/50 in the Eng, Primary but using the 75w-140 in the tranny. Switched over on a trip back to Iowa and the bike runs cooler and smoother. Again there are thousands of threads on this topic and like everything else everybody has opinion but I can tell u that u will not go wrong with amsoil.
