Has anyone changed their rear shocks? Was thinking about installing stock ultra shocks to cure the bottoming effect. Hope someone had some info, basically wound raise the rear to a Road Glide stock height. And is the stock front lowered or just the rear?
Did you pump up your shocks first. I am a big guy and mine would bottom out if I was below 35psi in the shocks. If the wife is on too I put it up to 40pounds and no problems.
I am considering doing the same thing. the more air pressure you put in, the stiffer and rougher the ride. I have tried up to 45 lbs. I am over 200lbs. Looking at changing the seat as well to something softer. I am tired of the log wagon ride but don't which option will be the best
