Question on Cam Chains/Cam Gear Change out
I have an 01 RK with 28K miles. I am thinking about changing out the cam chains to an S&S Gear Drive. A local small shop told me I also had to install a Power Commander, which I thought was completely wrong. I am not really crazy about putting in a Power Commander, I have heard some bad stories about them. Any thoughts on this.
I take it you got an 88 with the original cam tensioners?
I've got an 88 and my plan is to convert to the new hydraulic tensioners.
From what I have read, going to gears has it's cons like more noise. I think the kit comes with new cams which require new lifters and a tuner. They say it up's the HP, but that's only good if that's what you are looking for.
Yeah, that S&S catalog is a good thing. Be careful with it tho, the urge to chase more power may come over you....
When I switched to gear drive and a new intake system I considered the Power Commander or SERT but the dealer told me the 01 RKs came with the Magnetti Marelli EFI and it wasn't compatible with either. Do you know if your EFI is Magnetti Marelli ?
