Question on Cam Chains/Cam Gear Change out
My 1999 EGC has Magnetti Marelli EFI, and I run a PCIII, purchased from site sponsor Fuel Moto, which they dyno tuned YESTERDAY (Saturday).
Here's the link on the Power Commander website:
http://www.powercommander.com/powerc...mdl=31&yr=1999
In regards to if the 2001 is an M & M ignition, yes it is. Power Commander makes one for it. I have an '01 and put on a PC, and had it dyno'd. The difference was amazing to say the least. With my true duals and intake it really gets up and goes now. I plan on changing out cams (once I return from Asscrackistan) to give it more bottom end tq (lost it after the true duals, but my thighs like it so much better). But the PC has been great on it. Just get it dyno'd after install (my dyno guy installed for free) and you will be happy. Hope this helps.
I know another supplier here with the andrews products will offer you a choice of a new cam plate/oil pump and or the addition of cams .
If a dealer or indi wasnt giving you the straight goods on products they sell why have them install the parts you are going to buy?
MM EFI for an 01 from what I hear is a little bit finiky( I dont know what or why), just some guys just dont like them, others hate the delphi system and have resorted to removing all the EFI compnents and going back to carbs. Well, that was the rage three years ago, dont know where they stand on that modafication today.
I heard something to the effect that if one of the tensioners blow up, Harley will upgrade you to the new type tensioners (if under warranty of course).
This is the most important thing. As far as the power commander goes, it really depends on what you wast out of your bike. A fuel management system is required to retune as the bike will run differently after swapping the cams. There are various fuel management modules available for your bike, not jsut a pwoer commander.
I agree witht he last post, it depends on what you wnat out of your bike. If you are changing the cams to anything other than stock, you will need to change the fuel.
As for the M-M and the PC III. Your dealer is full of sh**. I have a PC III on my '01 RKC and it works great. A big differnece between the PC III and just the harley download. I can't vouch for a SERT available for the M-M but the PC is certainly. Call Jamie at Fuel Moto and talk to him.
I'm also pondering a geared cam change next winter but it will be to a little more aggressive grind and go along with bumbing the 'ol 88 up to a 95.
RadioBob
12-06-2012 09:56 AM
