Seat and Backrest Question
They (HD) have a new quick release mount for the SG, it allows the mounting of the sissy bar and luggage rack separately, so you don’t have to mount both. Also this new mount will allow the install of the tour pack if you should decide on that later.
The driver backrest is fairly easy, a bracket installs under the seat, and the back rest slips through the slot in the seat and clips right in.
My recommendation get rid of that awful stock seat! Get a HD Sundowner, you won’t regret it.
Ditto on the Sundowner. Not as cool looking, but very comfy especially for the passenger.
As to the passenger backrest, I strongly suggest you purchase the 2009 4-point detachable hardware. Then you can add the detachable backrest. The backrest pad is extra of course. Then later if you want you can just buy the luggage rack and pop it on too. The 4-point hardware is also what you need if you decide to go whole HOG and buy a matching Tour-pak.
Yep, that's right. The passenger backrest installs in 3 parts basically...
Part 1 - Docking hardware. this is an attachment to the bike that stays on. there is a "2 point" version and a "4 point" version, with the latter being more expensive, but allowing more expansion. The backrest itself will use either. i.e it only requires the 2 point docking hw, but will use 2 of the 4 point hw just as easily.
Part 2 - the "metal" sissy bar (in effect). you can get the low, the regular, or maybe even the "high" version of the bar (can't remember if there is a high on the SG).
Part 3 - the pad itself. you have to get a pad that will fit the bar you pick in part 2. i.e. the pad for the "low" bar won't fit the "regular" bar (if I remember correctly).
I would get the 4 point hardware in part 1 because you can then later add the luggage rack if you need it, or add the entire tour pack. if you go with the 2 point you'll get your passenger back rest, but if you want to expand past that you'll end up with the 4 point hardware anyway.
I have the 4 point docking set up on my 09 sg. (sorry no pics) I can put on the passenger back rest and luggage rack on in seconds when needed. Part #s are
54205-09 Docking Hardware (4 point)
52627-09 Upright Std. height (sissy bar)
51633-06 Back rest (pad)
54215-09 Detachable 2-up (luggage rack)
You can have the just the passenger back reat and add the rack if needed
I picked up an Ultra Touring pack from craigs list PN # 94743-09 that mounts on the rack when extra storage is needed. You can add a detachable tour pack to the docking set. In the catalog it says you need to relocate your antenna...I did not have too, so dont buy that.
Easy directions and install.
Hope this helps
Hope this helps
