Hello guys, I just got my iso grips yesterday & installed it, the problem is the glue that included on the grips is all dried up. is there a particular glue that i could get from a local auto shop/hardware that can hold the new grips.
I dont want to call kuryakyn & wait for their glue.
Just go pick up some gel super glue. Make sure it's the gel style. When I have installed those in the past I have run circles of it around the diameter of the bar at the bar end, put it on heavy, and then tapered the gel toward the switch housing end. Then when I slid the grip on I twisted it on to completely cover the inside of the grip you may even work it back and forth a little until the glue starts to set, then squeeze the rubber parts of the grip and it should set up fine.
my left one came off while cruising trough Colorado, I stuck it back on after makiing two wraps with electrical tape on the bar. I was going to replace with golf club tape and forgot about it until now...
Wow, almost the same experience. Except mine was while riding in the Black Hills...yeeee haaaaw! I just used some duct tape and when I slid it on some of the wraps rolled over exposing some adhesive. I was going to re-glue it, but its staying on so well now, I going to leave it.
