2003 Ultra Classic
Old 06-19-2009 | 06:16 AM
Cody450's Avatar
Cody450
Default 2003 Ultra Classic
Local dealer has an '03 Ultra for sale with low miles. Appears to be priced decent enough. Were there any known problems/issues with this particular year/model that I should be asking about? TIA
Old 06-19-2009 | 07:03 AM
nvsteve's Avatar
nvsteve
Only issue I'm aware of is the main circuit breaker. There was a service bulletin on it.
The fix was to replace it with a higher amp breaker.
Old 06-19-2009 | 07:06 AM
robbie52's Avatar
robbie52
Two things I would check on are:
(1) Depending on the miles, have the cam chain tensioners been replaced?
(2) Has fork oil ever been replaced. 2003 model has a cartridge and requires fork removal to replace oil.
Other than that, no problems.
Old 06-19-2009 | 07:08 AM
Cody450's Avatar
Cody450
The mileage is 14, 000 original, so they say.
Old 06-19-2009 | 07:14 AM
robbie52's Avatar
robbie52
I would have them change the fork oil due to the age of bike. The tensioners should be ok till about 30K.
Old 06-19-2009 | 07:17 AM
flatfifth2003's Avatar
flatfifth2003
And replace them with gear drive when the time comes.
Old 06-19-2009 | 07:40 AM
aclass's Avatar
aclass
Good year. you should be good for a long long time. Just keep in mind the cam chain shoes around 30k.
Old 06-19-2009 | 07:45 AM
ANIMAL03's Avatar
ANIMAL03
wire for the rear injector breaks ( was made to short ) and the radio will crap out at about 25k. other than that it is a great bike.
Old 06-19-2009 | 09:50 AM
Cody450's Avatar
Cody450
Along those lines, anybody know what a "30 point Inspection" generally involves on used motorcycle?
Old 06-19-2009 | 09:56 AM
petemac's Avatar
petemac
Ask the dealer for a copy of what is covered in the 30 point inspection.
Quick Reply: 2003 Ultra Classic
