ARC Audio 6.5 Package Group Buy
Old 06-18-2009 | 09:10 PM
vertigo14's Avatar
vertigo14
Pop the Amp on top of HK radio with the velcro, run the power to the battery you can run the ground to the battery or a bolt on the frame(right side steering neck). Run the blue turn on wire to a switched power.. cig lighter will do. Install the rings and grill cloth, put the speakers on.. 3-4 pilot holes (i did) but they come with self tapping screws.. put them in. Hook up the speaker wires to the speakers and push the button for non-rca connection. Put in your 30amp fuse on the power line. Switch the amp to high output and turn your bike on... adjust amp to your likeing.. easy...at least with a batwing... roadglide might do things a bit differently on amp placement... lots of write ups on the install on the hdforms..look around
Old 06-18-2009 | 09:16 PM
Gtsdesigns's Avatar
Gtsdesigns
this is a great seller and a great amp, i tested it for a little before i sold it, and the amp is awesome... great improvement over stock and awesome price for this package... the install is pretty straight forward, if using the stock head unit, you will need to use the high level input of the amp for the signal (instead of rca.s), the amp fits inside the fairing and runs pretty cool, unless you are running it at 2ohm, which it still is relatively cool, for such a small package)... anyhow, as Firecap stated it should take someone about 1.5 hours, to complete the install, just take your time and do things one at a time...
took me about 30 minutes to install... but I am no where close to new at doing this stuff... anyhow enough of my rant, I have lots to catch up with...
Old 06-18-2009 | 11:11 PM
Firecap501's Avatar
Firecap501
Former Sponsor
yes they make the 4ch, but it will not fit in the fairing, Normally with the UC we upgrade the front and let the head unit power the rear speakers, only mod to the rear is to add a good handfull of polyfill to the pods.
Originally Posted by IBHarley
Firecap do they make a 4 channel unit yet
Old 06-18-2009 | 11:13 PM
Firecap501's Avatar
Firecap501
Former Sponsor
With the price that I am going to run this for I need a min. of 10 orders. I will go and edit the first post. Thanks for brining that to my attention.
Originally Posted by Hammer107
So is there a minimum number to qualify as a group buy or is it really not a group buy but more of a July Special Promotion?
I'm confused.
Old 06-18-2009 | 11:15 PM
hounddog1257's Avatar
hounddog1257
Originally Posted by Pork-Chop
what about the RG rings? are those ready?
+1 are they ready?
Old 06-18-2009 | 11:16 PM
Firecap501's Avatar
Firecap501
Former Sponsor
No wires to cut at all. I can install one in 45 min. The time consuming part is running the power and ground back to the battery. Power and ground to the battery, switched power wire to the outlet off of the head light harness, and unplug your stock speaker wires, and plug in the high level input and then install the rings and speakers tune it up and your done.
Originally Posted by Biggzed
My question as well........
Is this ARC amp "plug and play" with a stock head unit? I'm assuming no with your quoted 1.5 hours install time, but thought I should ask. How much soldering splicing, etc?
Thanks for the opportunity on the group buy/promo.
Zach
Old 06-18-2009 | 11:18 PM
103Eagle's Avatar
103Eagle
Sounds like a plan but would be interested in the improved digital amp. Did I understand that may be part of the deal?
Eagle Out
:icon _speaker1:
Firecap501's Avatar
Firecap501
Former Sponsor
Yes sir, I have been shipping 6.5 rings for the RG for several weeks now. I just shipped out my last set, but have an order that is supposed to be hear on wed. I will not be able to ship untill the 30th, I will be at the national H.O.G event here in OKC as a vendor.
Old 06-18-2009 | 11:21 PM
103Eagle's Avatar
103Eagle
OK, not an audiofile expert, just like my tunes loud. Questions, 09 HK head units use 2 ohm speakers. Your amp says 2 ohm stable, speaker link says 4 ohms. All this workie okie dokey? 09 Street Glide, so with this setup, what would power per channel be? THANKS !
Old 06-18-2009 | 11:22 PM
Firecap501's Avatar
Firecap501
Former Sponsor
The ARC XXD digital amps are not due till july, I will have one for testing next week. I have to get one in and see if it will fit in the fairing with a stock head unit. With the digital amp there are no high level inputs, so a High to Low converter will have to be used.
I will have a package with the digital amp after the testing is done, this buy is for the 125.2 mini amp.
Originally Posted by hounddog1257
+1 are they ready?
Quick Reply: ARC Audio 6.5 Package Group Buy
