Lighting on tourpak
Your bike has a tour pak wiring harness that is long enough to reach the tour pak and enter it a couple inches or so. It's probably coiled-up under the left side cover or zip tied to the frame under the seat on the left side of the bike. The tour pak side marker lights and Ultra tail light bar use that harness.
If you are referring to the tour pak spoiler/LED, it comes with a harness and connector for using the accessory connector under the seat, though you can splice the spoiler/LED into the side marker light/Ultra light bar harness in the tour pak. That's how mine is wired.
