Cam Change Report
Old 06-18-2009 | 12:51 AM
OG1's Avatar
OG1
yea im running the gears. my pinion runout was <.001 and lash was good. its not gear noise i am hearing its in the top end once it gets hot. i am allready used to it, just had the post assembly jitters worrying about any little noise
Old 06-18-2009 | 08:03 AM
ron1026's Avatar
ron1026
which pushrods did you use? If you used the adj. you could try putting in another 1/2 to3/4 turn of preload in.
Ron
Old 06-20-2009 | 05:46 PM
OG1's Avatar
OG1
Would like to add tho this thread:
I noticed i was getting some pinging under heavy loads and high throttle positions (basically only when near lugging which i know i shoulnt do) so i put -2 timing from 2250-3250 and 15-50% TPS and i cant make it ping now no matter how hard i try. I had been warned about this by several builders, but never found any reports of people having pinging issues with the 26's. I dont seem to notice the aforementioned top end noise anymore and have come to realize it is normal.
Old 06-24-2009 | 03:05 AM
OG1's Avatar
OG1
checked mileage yesterday burned through 2 tanks getting 43.5 mpg, which is an improvement of 2-3 mpg for me. pretty surprised since i havent exactly been easy on the throttle. very happy overall.
gipper
09-30-2013 12:21 PM
Prot
EVO
11
09-25-2013 05:30 PM
da_big_Guy
08-30-2010 06:16 PM
dlocke67
Exhaust System Topics
13
10-02-2008 01:12 PM
MaxShovel
Shovelhead
10-01-2008 05:29 AM
Quick Reply: Cam Change Report
