Can Some One Help! Starting Issues
I posted this in the Softail section but I know some of the guy's here are real good so if you have any ideas please help.
https://www.hdforums.com/forum/softa...-heritage.html
I posted this in the Softail section and will double-post here in case anyone might benefit.
This is a historical issue with the PCIII and newer PCV. The fix is to start the bike as soon as you turn on the ignition switch. Doing this should allow it to start immediately, and waiting longer for the check-engine light to go off is not necessary.
I start mine as soon as I switch on the ignition and switch to run, hot or cold. If not it takes longer to start.
Truknoris
18
10-15-2018 07:39 PM
