Clearcoat Problem
If it was a defect this would have started in a small area and increased over time. You would have noticed it before it got to this point.
Thanks for all the replies. I really don't expect the moco to stand behind it but was wondering if anyone had ever had a GOOD outcome with anything similar to this.
I'm suprised to see that condition as HD factory paint is usually very good. I agreee with the posts in regards to brake fluid. Brake fluid would cause a problem from the top down. This is obviously coming from the bottom up. I am in the paint business and we see this condition quite often. Mostly the cause is clear that is too thin and the suns UV rays are able to penetrate throught the thin layer of clear and start to break down the basecoat, causing this type of delamination. The thing is, this condition happens over time, and typically with metallic/pearl colors or dark colors that absorb much more sunlight. In your case, the bike isn't very old and the fender is down low so it is not as exposed as say a car hood. Also, HD powdercoat clear is just about as durable of a clearcoat out there, even if your bike it is black in color. Assuming you bought the bike new, meaning that it hasn't been repainted or it hasn't been sanded and buffed down too far, I would still take it into the dealer to try and get something resolved. It wouldn't be a bad idea to take it to a body shop and have the cleaocoat thickness measured with a mil guage. This may give you some ammunition for a resolve. Nice bike, sorry that this happened. Gold Luck!!
Joechief
Joechief
Joechief
Joechief
I had a similar problem on a 1995 Honda Accord in 2000 and it was well out of warranty. Honda fixed that (said it must have been bad prep) and a non-retracting seatbelt (safety issue) free of charge! Doubt Moco will do it, but it's worth pointing out and asking. It's like asking the hottest girl in school out on a date, you don't have any chance unless you at least ask.
