Notices
So - I'm the idiot, not the gas station
Old 06-17-2009, 04:33 PM
Anthony8858's Avatar
Anthony8858
Anthony8858 is offline
This happened to me ONCE.
First thing...dry the connectors.
Second...Use electrical grease.
Third...Make sure you place the connectors in a way that the larger side of the connector is facing downward. That would drastically reduce the chances of water getting in there.
  #42
Old 06-17-2009, 08:09 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Originally Posted by Triggerman
Get rid of the crappy PC and get a real tune . Your bike will run better. You will be able to get it wet(imagine that). And you will never have to worry about it letting you down. Wait till your 5hrs. away from anywhere and it fails-that sucks!
Maybe not the most ignorant but certainly one of the most ill informed statements made on this forum regarding tuning.
  #43
Old 06-17-2009, 08:39 PM
qwest's Avatar
qwest
qwest is offline
Well - I made sure it was good and dry, put some dielectric grease on the connections, taped it up good and put it back together.
The bike runs as good as new! A huge relief.
Thanks for everyone's advice.
  #44
Old 06-17-2009, 09:17 PM
Road Ranger's Avatar
Road Ranger
Road Ranger is offline
Originally Posted by qwest
1) Everything will be fine.
2) Power Commander will be unusable, but bike will be fine.
3) Bike will be damaged requiring electrical repair.
Lesson learned.
Anyone want to speculate on what might happen?
You'll be fine...I had the same problem with mine one time...Pulled it let it dry and re-installed it except this time I added some die electric grease and installed it under the right side side cover. No more problems after that.
transam7969
07-23-2020 11:18 AM
speedkills66
02-25-2015 11:55 AM
ultraherbie
09-27-2011 01:35 AM
cap'n morgan
06-10-2010 02:13 PM
GypsyRoseTattoo
Exhaust System Topics
06-26-2009 09:36 AM
Quick Reply: So - I'm the idiot, not the gas station
