Does tranny fluid have to be motorcycle specific?
Old 06-16-2009 | 02:56 PM
jcanrun's Avatar
jcanrun
Default Does tranny fluid have to be motorcycle specific?
In reading the various posts on oil topics and specifically, transmission fluild, it appears to me that the transmission fluid for our bikes doesn't need to be motorcycle specific since there is separate fluid for the primary/clutch. Is this correct?
Old 06-16-2009 | 03:01 PM
n8dc's Avatar
n8dc
Id bet any good trans fluid would do and your correct the trans, engine and primary all are separate.. What your are looking for is a good quality gear lube that wont break down and will help quiet the noisy transmission gears... IE: bananna peels ,saw dust or possibly Quaker oats ... The Quaker oats also doubles as a radiator sealer if you have a V rod..
Dave
Old 06-16-2009 | 03:29 PM
nvsteve's Avatar
nvsteve
No, but I'd go with a good quality synthetic.
Old 06-16-2009 | 06:31 PM
EdwardK's Avatar
EdwardK
It's a gear box. Use gear lube.
I use Mobil 1 75-90
Old 06-16-2009 | 06:45 PM
racklefratz's Avatar
racklefratz
The others have picked up on your apparent misconception. "Transmission fluid" is a term that is commonly used when people are referring to automatic transmissions, as in automobiles. Harley Davidson motorcycles don't utilize that kind of transmission. Harley's have "gear boxes" as "transmissions".
Use gear oil in a gear box, and further, my advice would be, don't buy into the "Syn3" hype from HD. It's not full synthetic, and it's not a gear oil. There are lots of discussions here on recommended lubricants.
Old 06-16-2009 | 07:57 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
I use Mobil 1 75-90
That's what I use and would suggest to you.
The primary needs a bike spec oil (JASO MA rated) to make sure it has no friction modifiers..the crap they put in car oil to get MPG but screws up the clutch in a FUBAR way.
The engine, I use Mobil 1 V Twin oil, but there are many other quality synths out there, and there are people who run cage oil in their bikes too. YMMV
Old 06-16-2009 | 09:13 PM
maineultraclassic's Avatar
maineultraclassic
I use Mobil 1 75-90
Exactly................it's a gear box so it needs a good gear lube.
I use Mobil 1 75w-90.
Steve
Old 06-16-2009 | 09:21 PM
Mick's Avatar
Mick
I've used Redline Shockproof Heavy and Amsoil 75w90 in my gear box.
Both work well and quiet 5th gear a bit too.
Any quality full synthetic gear lube should work just fine.
The Redline looks a little funny like pepto bismol , but is a favorite around here.
Mick
Old 06-16-2009 | 09:28 PM
cruise_carter's Avatar
cruise_carter
Using Redline Shockproof Heavy, used it in my 02 RG and 02 EGC, tried other lubes but best results in this stuff..
Old 06-16-2009 | 10:24 PM
Sharknose's Avatar
Sharknose
That is correct. It needs to be Redline Shockproof Heavy. It might be difficult to find over the counter, but you can order it online. I bought a gallon because with shipping costs included it wasn't that much more.
Quick Reply: Does tranny fluid have to be motorcycle specific?
