RKC Front brake squeal
Old 05-17-2006, 03:38 PM
anzac's Avatar
anzac
anzac is offline
Default RKC Front brake squeal
I know someone went over this before but could anybody tell me how to stop the front brake squeal on my RKC 2006, I put new pads in and was careful braking them in but it didn't do any good.
thanks for any reply
Old 05-17-2006, 03:46 PM
flames95's Avatar
flames95
flames95 is offline
4th Gear
Default RE: RKC Front brake squeal
I also had a 2006 RKC with front brake squeal. When I brought it in for the 1K check I mentioned it to the dealer, they fixed it. They flipped the rotors from the left side to right side and the squeal hasn't come back yet, 2K later. Others have changed the front rotors to floating with the same results.
Old 05-17-2006, 04:27 PM
RBJones's Avatar
RBJones
RBJones is offline
Also, do a search on this forum and it will bring up other suggestions.
Old 05-17-2006, 04:36 PM
Hardly Dangerous's Avatar
Hardly Dangerous
Hardly Dangerous is offline
Swap the rotors left to right.
Old 05-17-2006, 06:19 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
You can do a few things to eliminate the squealing. The squeals come from brake dust getting in between your caliper pistons and the back of the brake pad. Some folks have switched left/right rotors, changed brake pads (to Lyndall or SBS), and kept the calipers/pistons cleaned.
A more expensive way to go is switch to floating rotors and Kevlar brake pads.
Lyndall Racing also has detailed instructions on how to remove and clean your calipers.
ORIGINAL: anzac
Old 05-17-2006, 08:04 PM
Warpig's Avatar
Warpig
Warpig is offline
I have a somewhat of the same problem except my front brakes just rub a little (no squelling). When I'm pulling my bike into the garage I hear a slight rub rub rub as I roll in. Any suggestions on how to fix this problem, the pads look fine but it seems thay are staying down or closed.
Old 05-18-2006, 11:34 AM
Hardly Dangerous
Rubbing is normal. That's what they have always said although you might start growing hair on your palms.
Old 05-18-2006, 11:37 AM
JamieCarr's Avatar
JamieCarr
JamieCarr is offline
I got the squeal too,...I just live with it.
Old 05-18-2006, 11:39 AM
bountyhunter's Avatar
bountyhunter
bountyhunter is offline
Floaters, paid $88 each. Brakesqueal really sucks, no need to live with it! Dump the stock rotors (and exhaust)![sm=bangbang.gif]
Old 05-18-2006, 12:31 PM
venture33's Avatar
venture33
venture33 is offline
At 1K service the dealer sprayed foam (yes, the crap you buy at Lowes) in the hubs. Helped alot
Quick Reply: RKC Front brake squeal
