xm sattelitte radio kit for the stock hd radio
i am trying to get info on the harley davidson xm sattelitte radio kit for the stock hd radio , i have a 2002 road glide and i have the 06 and later harmon kardon stereo in it , i would like to hook up the harley accessory xm radio , i bought the xm kit and the non ultra interconect wiring harness for it per the instructions in the hd accessory book , when i tried to plug it in i found that the bike has a three pin triangle style connector and the harness has a six pin square style , does anyone know how to hook this up correctly or if it can be done . any help would be great . thank you .
Not sure which connector you are refering too, but my XM radio, "ROAD TECH" made by HD, is secured to the left hand grip housing on the handle bar with two bolts and just simply plugs into the aux. plug on the bottom right front of the HK radio system. Also, it has to hook up to a 12V source to power it up. You set the radio to "AUX" and the XM works. It will play thru the speakers or flip the switch and it plays thru the head phones. PACO
Dagurley
09-21-2018 04:28 PM
