09 Touring models - tech bulletin to be released - noisy when hot
09 Street glide - quiet when cool, after it warms up excessive noise from transmission - but quiet when clutch pulled in, sounds like a can of rocks, initially thought it was valve train issue, but narrowed to transmission - but when you pull the clutch in, the nose goes away, let clutch out - noise comes back
UPDATE - apparently no tech bulletin coming - HD layoffs have cut their research and tech department
similar complaints from other riders on forum who have emailed me
HD is aware of problem, but has no solution - will not take bike back - noise started at 250 miles...
so much for harley warranty and the Harley Experience...local dealer has been great, but the HD rep basically said screw me....going with a victory next time...will pursue Lemon Law
09 Street glide - quiet when cool, after it warms up excessive noise - but quiet when clutch pulled in
apparently it's not "normal" harley tech is aware of the problem in 09 models - has plans to issue tech bulletin to advise fix - but hasn' t gotten it through R&D so if you do experience problem push your dealer for call to HD tech department
If that's the case, I'm not loosing sleep over it....
What kind of noise?
