Did you ever try to powder coat somthing ?
i've heard about being able to do powdercoating at home with an old oven - how did it turn out?
i have a small piece i'm looking to do about the size of cell phone and I have an old oven to use.... how much would it cost to have someone powder coat just 1 small piece or will it look good by me doing it at home?
any advice?
(its a piece up on the dash area so it will be very noticeable)
any advice?
Years ago I knew guys that would do this at home, but the products weren't that great and the pieces were not critical to aesthetics, foot peg brackets, muffler mounts, etc., nothing that would be noticeable. They used it as an alternative to just painting black using a spray bomb. If it is going to be out and noticeable, I recommend a commercial house.
Just my
Just my
My brother and I have done this exact thing for years using some equipment from Eastwood (http://www.eastwood.com/). The quality has varied depending on what the part was, the condition of the part, and the prep. It needs to be cleaned well and you need to take your time to do it right if you care how it turns out. It's hard to control the thickness of the final product, so keep that in mind if something is a tight or snug fit, it may need to be filed/sanded/ground.
Also, you should use an electric oven, not a gas one. Something I read long ago said don't do it, i don't think it could be that the powder is the issue, (IE, flammable) so much as the gas flames can disturb the powder during the cure (or melt). The best part is, if you mess up, just remove the powder coat and start again.
