Vibration on handle bar due to tire cupping?
Old 06-10-2009 | 04:05 PM
c50plus's Avatar
c50plus
Default Vibration on handle bar due to tire cupping?
My front tire pressure is currently to specifications and I have no spokes. So what is causing a very mild vibration when I transition from 30 to 35 mphs (either up or down). A very good mechanic mentioned this could be due to tire cupping. I did not have the bike with me so he could not check the tire but have never heard of this. I looked at the tire and I am not sure if I can tell. Any advice? Thanks
Old 06-10-2009 | 04:11 PM
EricD10563's Avatar
EricD10563
Don't know what year your bike is or tire, but some are complaining about cupping on the 09 models. I have some cupping on my front tire and there is a slight vibration because of it. I have 8k miles and it started about 4k ago. I can see the cupping can you?
Old 06-10-2009 | 04:59 PM
c50plus's Avatar
c50plus
My bike is an 08 Ultra. I am not sure I know how to check for the cupping.
I heard cupping is dangerous in wet surfaces. Is that true?
Old 06-10-2009 | 05:16 PM
JacktheBagger's Avatar
JacktheBagger
every bagger I have had has cupped the front tire , if any vibes , never noticed it ..
Old 06-10-2009 | 05:28 PM
mickael moore's Avatar
mickael moore
Smile
I've had cupping before to on both tires. Now I use DYNA BEADS (2oz) both tires. I get beautiful smooth ride not counting bad roads. Tire last longer and are always in balance. Great inprovement in ride. I don't sale them, I just use them.
www.dynadeads.com
Once A Marine, Always A Marine
07 Ultra
Old 06-10-2009 | 05:35 PM
FLoTR's Avatar
FLoTR
Just rub the dirt off of the tire's tread with your bare hand, laying across the tire, rubbing from front to rear. If you dont feel the bumps going under your fingers, then it's probably not cupped. That being said, I should probably go check mine because I have that vibration too. Kinda scared to look with only 3600 miles on it.
Old 06-11-2009 | 12:35 AM
kirksharley's Avatar
kirksharley
6th Gear
Every front tire I have ever had has cupping, but never noticed it in the bars. If the front wheel is not balanced you will notice it in the bars. Look to make sure the wheel weights havn't come off. If they are still there, pull the front wheel off and have it re-balanced.
NCTim
06-02-2023 10:48 AM
Grey_Fox
12-03-2015 10:24 AM
R Hill
The Dark Side
09-21-2013 08:08 AM
Tx_Outlaw
07-17-2006 01:58 AM
HDF Tech
06-25-2005 12:36 PM
