stupid question ABS?
06-10-2009, 12:09 PM
how do I know if I have abs on an 08 SG. I bought it from a dealer that new nothing about the bike I new it had cruse & alarm just by the picks. I know this is kinda dumb
Teke
06-10-2009, 12:11 PM
The easiest way to tell from looking is to look at the front wheel on the right hand side. If you see a black spacer looking ring on the axle - you have ABS.
06-10-2009, 12:14 PM
the other option
Or, (not recommended) you could run about 70 on a dirt road and lock up both front and back brakes. If you survive you have ABS.
06-10-2009, 12:21 PM
On my Ultra the speed sensor is on the left side of the front wheel.
It looks like a black spacer with a wire attached to it.
06-10-2009, 12:24 PM
On the caliper itself it will have a small plastic piece that says ABS...also - when you start the bike there should be an ABS light that flashes until you get moving more than a couple miles per hour...of course this is from a Road King guy...
06-10-2009, 12:27 PM
thanks for the info based on this I don't have ABS
06-10-2009, 12:45 PM
Quote:
Originally Posted by
dogpound
...when you start the bike there should be an ABS light that flashes until you get moving more than a couple miles per hour...
This.
06-10-2009, 07:42 PM
If you bike stops quickly on a slick surface and stays upright, you have ABS.
If your bike takes a long time to stop and your name is kingkingking, you have ABS.
If your brakes lock up and your dump your bike when braking, you don't have ABS.
jamie_s_72
02-14-2017 06:58 AM
BALLS172
04-05-2014 07:09 AM
etstrine
08-25-2012 08:12 AM
jimmyjamesallen
01-02-2010 12:09 AM
dcassavar
08-30-2009 11:58 PM
