I have a crazy oil pressure question for the mechs in here.
Old 06-10-2009 | 04:35 PM
sgdiesel's Avatar
sgdiesel
I am no expert in the specific design of the engine so I am reluctant to speculate on the damage that overpressurisation will achieve, but...
I don't believe the damage will manifest itself as seal damage as the seals (and certainly gaskets) are all at crank case pressure which is vented, hence atmospheric pressure irrespective of pump pressure.
From purely a hydraulics perspective, Power = Pressure x Flow. The pumps are positive and fixed displacement pumps, which means the flow they deliver will be consistant for a given engine RPM irrespective of pressure (in theory). So, practically speaking by drawing the extra pressure you require more power to turn the pump so you will suffer a loss in brake HP, but most importantly you are doing no work with that extra power so it goes entirely to heat, so your engine will run hotter.
How much hotter and how much power loss I cannot so as I do not know the displacement of the pumps, but the bottom line is you are losing both ways.
In addition to this, I would be concerned about excessive wear on the pump as they are almsot certainly optomised for lower pressures
Old 06-10-2009 | 08:17 PM
jdreed520's Avatar
jdreed520
Thanks for that incite, I didn't think about the power loss or the heat.
Old 06-10-2009 | 08:44 PM
rbabos's Avatar
rbabos
Spot on, on all accounts.
Ron
Old 06-11-2009 | 01:14 PM
jdreed520's Avatar
jdreed520
Ron
THanks rbabos
Old 06-11-2009 | 09:46 PM
jdreed520's Avatar
jdreed520
Well i pulled the button and the oil pressure is 40 cold and about 8 warm at an idle. Thanks to all of you for your imput.
Old 06-11-2009 | 10:25 PM
texaswiz's Avatar
texaswiz
One of the reasons the newer 96 inch twins need to idle at 950-1000 rpms is to address the problem of low oil flow at low rpms. Most of us have noticed that the newer fuel injection bikes do not have that old familiar "pototo-potato" exhause note. Those older carbed bikes would idle at 750-850 rpms or so. The newer bikes need a few more rpms to keep oil flowing across the bottom skirts of the pistonians. They seem to be happy with 32lbs or a wee bit more at cruising speed and 8 lbs or so at hot idle. If your bike shows something like that then all in Harleyville should be happy.
Old 06-11-2009 | 11:08 PM
jdreed520's Avatar
jdreed520
Thanks a Bunch...that is where I am at now.
Old 06-11-2009 | 11:24 PM
1ADAM12's Avatar
1ADAM12
here is a dumb question what and where is the spring and or button?
FL-kruzen
11-13-2012 04:50 PM
simpkinst
07-09-2011 04:14 PM
jdreed520
Exhaust System Topics
06-10-2009 08:12 AM
Hiawatha Al
06-09-2009 06:49 AM
jjb
11-21-2006 05:02 PM
Quick Reply: I have a crazy oil pressure question for the mechs in here.
