EG, adjusting passing lamps, help!
Old 05-16-2006, 10:19 AM
Varooom's Avatar
Varooom
Varooom is offline
Default EG, adjusting passing lamps, help!
I have an 06 EG standard. I need to adjust the passing lamps ( I don't think the MOCO or dealer adjust these at all, just slap them on). I have a service manual and it sounds very simple.
Remove the turn signal indicators by removing two screws each. Under the passing lamp in a nut. Loosen the nut, adjust the lamp, tighten the nut, and replace the turn signal.
Simple enough.
Problem is getting to the two alen head screws that hold the turn signal on. I have attempted this twice and quit. My guess is about an hour each side to remove the turn signals, then an hour each side to put them back on. There is very little room to turn the alen wrench. Very tiny little turns at a time. I just don't have the patience.
I know there is a better way, any ideas or experiences would be appreciated
Thanks for your time,
Doug
Old 05-16-2006, 10:27 AM
liltrk's Avatar
liltrk
liltrk is offline
Default RE: EG, adjusting passing lamps, help!
Do you have a ball ended allen wrench? That may help. Most guys complain about the nut on the passing lamp. It is more difficult than the signals IMO.
Old 05-16-2006, 11:21 AM
wildcat641's Avatar
wildcat641
wildcat641 is offline
Get a set of ball-tipped allen wrenches.
Old 05-16-2006, 12:01 PM
Bruce00's Avatar
Bruce00
Bruce00 is offline
what was said about the ball end allen wrenches.............makes life sooooooooooooo much easier
Old 05-16-2006, 02:11 PM
Varooom's Avatar
Varooom
Varooom is offline
Thanks guys, Ill be getting some "ball end" wrenches.
Thanks again,
Doug
Old 05-16-2006, 04:04 PM
RBJones's Avatar
RBJones
RBJones is offline
Anybody found a suitable and cheaper replacement for the Snap-on flare nut socket FRX181 that holds the passing lamp?
Here's what it looks like
http://buy1.snapon.com/catalog/item....2&group_ID=262
Old 05-16-2006, 04:17 PM
BluegrassBuck's Avatar
BluegrassBuck
BluegrassBuck is offline
ORIGINAL: RBJones
You could buy an entire set of chinese deep sockets (the black ones not the chrome) for about $10 and take a sawsall cut the one size you need out like the Snap-on one. Put it a vise and keep oil on the blade as you cut. Smooth it up with a file and belt sander, then paint it to prevent rust.
Old 05-16-2006, 05:39 PM
tmf2's Avatar
tmf2
tmf2 is offline
>>Anybody found a suitable and cheaper replacement for the Snap-on flare nut socket >>FRX181 that holds the passing lamp?
I took a 9/16 deep socket and cut down the length of the socket so
the socket can slip the wire in and out the bottom. Then I use vise grip
and clamp on to the socket works great for me.
Dennis
Old 05-16-2006, 06:03 PM
RBJones's Avatar
RBJones
RBJones is offline
That's a good idea. I'll have to go shopping at the tool bargain bin. Those cheap sockets should be easy to cut because they work about one time on a nut before they stretch out an become worthless.
Old 05-16-2006, 06:42 PM
liltrk's Avatar
liltrk
liltrk is offline
I think I would use a good socket to cut up. I know it hurts, but if the cheap ones stretch normally, how bad are they going to be with a slot in the side?
Quick Reply: EG, adjusting passing lamps, help!
