Detachable tour pack/amp ???
Hey guys and girls. Long time voyeur, first time poster...I have an 06 electraglide standard with the HD CD/radio and detachable tour pack with rear speakers. I cannot figure out a way to remove the tour pack without cutting the rrar speaker wires....BTW, to further complicate things, the HD amp is mounted to the bottom of the tour pack. This means the rear speakers go into the wiring harness that plugs into the amp. Long story short..(too late)..when I remove the tourpack, the amp comes with it, so only thing i can think of is cutting the rear speaker wires or mounting the amp in a saddlebag (only place i can find where wires will still reach. But then, i think i might run into heat issues if it sits in the closed bag. Any ideas???
Tom from http://harleygoodies.com/ here. there has to be a better way than that. Will your amp fit in the batwing somehow? If so cut those rear speaker wires and rewire all that stuff to the rear speakers with a quick detach for the rear speakers when you want to take the tour pack off.
Regards,
Tom
Harley Goodies
Regards,
Tom
Harley Goodies
If it is the standard Radio Sound amp and speaker pods (like mine) , there is a connector in line for each pod, and the connector that plugs into the amp.
You remove the connector from the amp, and the connectors from each pod, and take the tour pack off (remember to disconnect the antenna wire and lighting connector inside the tour pack as well.
I marked the pod connector on one side with a cable tie so that I would plug them into the correct side when reattaching.
Remove the seat and the wiring harness can be rolled up and fit under the seat behind where the battery goes.
