after storage start up
So my bike has been sitting since November of last year (7 months) without being started. Should I cycle the starter button a couple times to bump the oil around before attempting to start it or just hit the starter and see what happens? Is there a way to spin the crank like on a car engine? I plan to change the oil prior to starting it to ensure that it has good oil and the proper amount in it.
Thanks,
BM
Thanks,
BM
Check tires for dry rot/damage. Air in shocks if equiped, spark plugs and wires.
I would ride local with another rider and carry a small tool bag just in case.
I'm sure all will be fine. Maybe carry some additional fluids in case a gasket has gone south and leaks. Let us know how it went
Enjoy and be safe
Tank is dry. The reason for the storage without starting it was becasue the tank was off it being painted with the other pieces. I guess I'll do as suggested and let the bike idle a little while before swapping out the fluids. My only other question is, are the fuel lines supposed to seem "loose" when installed in the tank? I tightened up the 3/4" fittings, but both lines seem to have a lot of motion in them. I also had the forks off for a progressive 1" drop so they have fresh heavyweight fluid and springs but still need air (thanks for the reminder!) The rears were also swapped out with Progressive 440s. I'd like to change out the plug wires but I'm not sure what to buy. I'm more of an upgrade when replace than a replace with OEM kinda guy. Any suggestions?
take only short rides near home for the first while, i'd think, that way in case something is wrong, you aren't stranded. after a fresh fuel up, and checking all of the initial stuff you should be good to go huh?. can't believe you haven't started it in that long. should be okay though. have a good ride and enjoy the summer.
Haji4
01-20-2006 07:02 PM
