excessive heat on 09 ultra
Old 06-09-2009 | 02:01 AM
emwolb's Avatar
emwolb
none of you guys saw how anthony hopkins cured the heat issue on his old indian in the movie, "worlds fastest indian"? asbestos wrap. hope you find a legitimate cure though, as there have been a bunch of 09's sold and the heat issue has come up many times
Old 06-09-2009 | 03:15 AM
flylock's Avatar
flylock
Mine is definitely running warmer than the old dyna was. The oil cooler with a built fan looks interesting, may have to check into that a little more.
Old 06-09-2009 | 05:57 AM
timvan's Avatar
timvan
Stage 1 .. get rid of the epa crap, add fuel/air
Old 06-09-2009 | 01:12 PM
dougyf's Avatar
dougyf
Default heat on right leg
I think with the redesigned exhaust that the result is less heat on your right thigh, but more heat on your right leg. It seems to be more noticeable when the sun is out or after you get stuck at a few red lights. Its even noticeable at speed some times.
Old 06-09-2009 | 05:41 PM
07JakeelwoodHD's Avatar
07JakeelwoodHD
I did the FM PCV Rhineharts and SE AC KN filter still runs hot next step is the oil cooler
Old 06-09-2009 | 06:33 PM
Twinrider's Avatar
Twinrider
I've got a PCV mapped by Jamie, Stage 1 AC, an oil cooler and am running synthetic. Heat seems to no longer be an issue.
garyhendley's Avatar
garyhendley
you would think by now that they would have fixed the heat issue i am hearing
a lot of complaints about the 09's now-ride safe
Old 06-09-2009 | 06:39 PM
Twinrider's Avatar
Twinrider
A lot of complaints? More like a few from people who are new to having a 96 CI motor between their legs that is tuned to meet stricter EPA standards.
Old 06-09-2009 | 06:47 PM
harleyflyboy's Avatar
harleyflyboy
Yes I went from an '05 Ultra to an '09 a few months ago, and the '09 runs much hotter. The first thing I did was remove the lowers,( have to in south Texas anyway) with not much noticable difference. Am giving a lot of thought to a Power Commander or something similar and running a little richer.
Old 06-09-2009 | 06:59 PM
Twinrider's Avatar
Twinrider
That'll fix it, give Fuel Moto a ring.
Quick Reply: excessive heat on 09 ultra
