Lesson Learned
I changed my tranny and primary oil today and after getting the primary all buttoned up and the area cleaned up. I had the bike running sitting on a block under the jiffy stand and also under the right side stand I made. I turned my back for a second and am guessing the jiffy stand lock wasn't locked and down it went. Man, it is scarey when you hear that noise with your back turned. Hollered at the wife and she ran out and we got it back up on the jiffy stand. Spilled gas(can't figure where it came from)all over the garage floor but no damage to bike. Finished cleaning up the mess and rolled it outside and let it sit for a few minutes, took the leaf blower and dried up the gas off the floor and just to be safe went over the bike with it. Started her up and she ran just fine, no leaks and still don't see any damage from the drop. Scared the **** right out of me, I can tell you that. Guess next time will come up with a set of chocks or take off blocks before I run it.
Joe
Joe
Didn't really see a fire hazard, leaf blower was electric and I was a safe distance away not right on top of gas. I had already dried most up with disposable towels, and they were in the burn barrel down behind the shop. Thanks for the advice, will be more careful next time.
According to the manual I should have only put 32 oz of oil in the primary, but I couldn't see the oil level as stated in the book. I add some more, maybe 10 oz or so. Should I drain the oil out, and refill using only a qt.
Joe
Joe
Joe
Joe
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
When I fill my primary with the bike on the jiffy stand 32 ounces comes just about to the bottom of the primary cover.
Joe
Joe
You sure you didnt put the oil in the wrong hole? You should see a quart and 10 more ounces should spill out. Someone correct me if I'm wrong.
I had the bike standing straight up as the manual says, If I had it on the jiffy stand it wouldn't have fallen over and yep a qt would have most likely filled it up. So I should go drain out the oil and fill it on the jiffy stand not standing straight up as the owners manual says. Thanks for the info.
Joe
Joe
Joe
Joe
all depends on howmuch gas was/is on the floor... gas itself does NOT burn - its the fumes that ignight and the Elect motor is enough to do just that IF the air/vapor is correct.. I have been to many garage fires in my career where gas fumes and the smallest ign source sets off a blast...
Life is just a series of lessons learned - Like a lot of people, I have made the mistake of removing the wrong drain plug and emptied the trans instead of the oil....lol..
