Question on installing EZ Adjustable pushrods
Heres where I am at...
Installed all four pushrods....found TDC for front cylinder and adjusted rods out 3 turns(instructions say 3-4 turns), waited 10 min and both rods spun freely.
Turned rear tire and found TDC for rear cylinder. Checked front rods and the intake is still loose but the exhaust is tight..cannot spin it.
Installed rear pushrods and adjusted 3 turns out. They are bleeding down now and starting to loosen up. Front exhaust is still tight.
Is it normal? Do they each take a turn going tight as the cam turns? Hope that makes sense.
Dont want to turn tire again until I know for sure.
FWIW...If you ever install them spend the bucks for the short covers. I didnt and payed hell getting everything in.
Thanks
Thanks
You figured the front cylinder sits still while you find top dead center on the rear? The exhaust valve for the front cylinder is open! Pull the plug, get a flashlight, & look in the hole! You want the push rod loose while the cam lobe is up?..............Probably not!
"Do they all take a turn going tight as the cam turns"....... Are you serious? No, the cam just rotates & the valves stay shut! Saves on gas.........
Everyone has to learn sometime..........you should try it.
each cylinder has two TDC positions, TDC compression and TDC exhaust. hope you didnt *** anything up turning it over like that
edit: i re read your post and it doesnt sound like you would have messed it up, but yes on compression TDC for the rear cyl, the front exhaust valve will be open
Thanks OG1.. thats what I needed to know.
Jinks...what the **** is your problem? If you wanted to be a dick you should have just stayed out of the thread. Seems like just another keyboard cowboy.
MODS...If you want to pull this thread go right ahead. It will probably go downhill from here and I got my answer.
Reread my post. I didn't call you any names. I answered your question & added information that would verify what was happening. Didn't fit the kind & gentle response you wanted? Neither will not understanding what goes on in a motor & doing things to it you don't understand. Keyboard cowboy? No, but I can adjust the valves on a Harley, & know what I'm doin'.
I wont finish it till Sun because I am about to head out of town.
Everything else went good. I took it apart to check/change the cam chain tensioners. Outer had little wear but inner was almost completely shot. 33k miles on bike. Was going to change cam out but other bills came up so it will have to wait for awhile. Used the manual and http://www.harleyhog.co.uk/tensionerinstall.htm to walk me thru the steps.
The only step I didnt do was the heat/freeze to remove cams from plate. I just took the plate to the local HD shop and they pressed out the cams and replaced the bearing. Cost was $50. 1st time I walked out of there without spending over $100. Only because I brought in the cam chain tensioners with me.
