Changing oil filter
I've tried making gizmo's to keep the oil off the engine (and I'm too cheap to buy one) but they don't seem to work that well. They slide and move and I seem to get oil on the front engine mount and frame anyway. I've just gone with draining the oil pan thoroghly and just pulling the filter as quickly as possible and letting the oil go where it may. I just use it as a good excuse to give that area of my bike a good cleaning. Its not that messy.
Good luck.
Good luck.
I bought a roll of Heavy Duty Reynolds Wrap years ago. I tear off a piece big enough to fold for two layers, make a narrow spill-way that slips under the filter. When you loosen the filter a little oil will drip in the spill-way & run to a catch pan I place at the end. After the filter comes off I wipe the filter mount & fold up the Reynolds Wrap. No drip, no mess. One box of that stuff has lasted for years..........
Take a 2 liter soda bottle and cut off the bottom. Then cut a 3" wide by 6" long piece from the bottom up the side. Basically a wide notch. Loosen your filter and then slide the bottle up around the filter and continue to unscrew it thru the notch you cut. It will collect the oil and filter. Don't forget to leave the cap on.
I use a pop bottle , with the bottom cut off. I have one of those filter caps that fits over the filter and fits onto a ratchet drive. Slide the bottle over the filter as far as it will go and take the bottle cap off. Then using a 12 inch extension on the ratchet, put it thru the bottle opening and into the "filter cap". Start loosening the filter and once its off, pull the extension off, put the bottle cap back on ( to catch the oil ) and let it sit while you get ready to put the new oil in the bike. When you're ready, pull the bottle out with the filter and oil in it and dispose of them properly.
No mess, and has worked for me for over 5 years.
It is tight getting the bottle in and out because of the shifter, but it is doable.
