Cam swap only????
Cam swap only????
I have an 08 RoadGlide that is stock except for Bassani 2 into 1 RoadRage pipe, HD heavy Breather and SERT tuned by my local dealer.
Bike runs great (76hp 88tq) but I need a little more low end grunt (torque).
I will be doing a 103 build this comming winter with proper headwork, compression, and cams to match.
I am taking the exhaust off this weekend for some cleaning and other astetic changes.
I was thinking that while I have the exhaust off it would be easy to slap in a set of SE255 cams. I would not change the cam bearings (will do that this winter) just cut the pushrods, install the cams, and put adjustable pushrods back in.
I figure I can do it in a few hours and have a little extra grunt at the bottom until I do the motor right this winter.
The bike will see only about 5 to 6 k miles before the winter build.
So the question is can I get away with just changing the cams, not the bearings untill later or am I absolutely nuts to change the cams without the bearings for any amount of time?
Any other good cams for low end torque in a stock 96"?
Thanks for your time,
Doug
Doug
I don't know of any cam set for the TC96 that will provide the low-end grunt and good midrange muscle the 255's will on a stock TC96. All this talk of 203's and 211's beating the 255's for low-end grunt with a stock CR just isn't possible given the specs of these cams. As everyone knows the 255's won't win any peak-HP dyno shootouts, but for the application that the 255's fit best (heavy touring bikes) peak-HP is not the highest priority for most riders.
Not for low-end grunt in a stock TC96. Increasing CR, do headwork, increase displacement, etc. is another matter.
