Blowing fuse with brake/turn module
I have an 01 ultra and cannot use the turn signal/brake light module as the fuse for the running lights blows when you use the brakes. With the module in & after the bike runs for a few minutes, when you hold the foot or hand brake the fuse pops. I unhooked the rear brake switch thinking that might be the problem, but it made no difference. Without the module everything is fine.Am running out of ideas. I might have to take her to the shop. That might get expensive.
is this a new development? have you been running this module and all of a sudden this started? or is this a new module?
if it is an old module (as in you've been running it for a while), they do go bad. i had one that i had to replace cause it just decided to stop working completely. didn't blow any fuses, but just stopped working.
Tom here. It sounds as if something is improperly grounded somewhere in your system. Wiring is a PITA. I also had one of these go bad on me and it took me several weeks to figure out it was the module, not the signals or brake light. Never again. Took it off and never looked back.
Regards,
Tom
Harley Goodies
Regards,
Tom
Harley Goodies
Thanks for the replies. The original module went a few years ago. The module & a different fuse went at the same time. I blamed it on an overloaded circuit as I was running a sat. radio. Maybe that was not the case. I have the lighter outlet fused alone now. I got a replacement module last year & this has happened every time I've tried to use it. I went through 2 packs of fuses trying to isolate the problem. I was hoping the brake switch would be the answer. Too easy I guess.
OK I tried some more stuff & went thru some more fuses. I took the bulbs out of the turn signals & didn't blow a fuse. Put in one bulb and no blown fuse. Put in 2 and blew the fuse. Did this twice with same result. Put in the old module & it is just a brake/turn. Does this mean that I need a different bulb for the run/brake/turn? I'll switch bulbs with my buddy & find out. Thanks
