Where is all the turbulence coming from?
Old 06-01-2009, 07:11 PM
JohnScrip's Avatar
JohnScrip
JohnScrip is offline
Being on my *NINTH* shield (on my 08 SG) I've come to three conclusions:
1) http://www.denniskirk.com/jsp/tpl/pr...mmyId=11800113
I hope that shows... It's a 12" Memphis Shade shield with a black gradient. "Keeps the designer's intentions" better than most, but puts a 12" shield in front of you. Overall, probably the best solution I've found.
2) Clearview... I have a 9.5" Clearview recurve. Below ~45MPH, that thing has no equal. Above 55 or so, it's like having your head in a paint mixer (just like pretty much everything else under 12").
3) With a VERY (*VERY*) rudimentary knowledge of hydro/aerodynamics, I made my own shields out of Fastaire 9" blanks and a heat gun. With one, I lit a cigarette at 35MPH with a Bic and built up an ash at 70. A guy asked me "Is that one of those (Klockwerks) "Flare" things?" -- I had no idea what he was talking about, but after doing a little searching, I found them. It did look very similar. But after trying one (6.5"), mine worked much better. The big problem is that the thing was very "rough" (I shaped it by hand - With a heat gun and oven mitts) and it was about the ugliest thing you'd have ever seen. THAT SAID: I wrote Klockwerks about it (as I found they had a patent on the design and didn't want to step on any toes) to see if they'd be interested in making a taller shield. No responses after several attempts last year.
This year, they came out with a 10.5" Flare. I figured that would be too tall (which is why I went with the 9" in the first place - I'm 6', BTW). From what I'm hearing through the grapevine, people aren't liking it much - Too flexible and causes too large a vacuum on the rider side.
If they'd split the difference and make a 8.5-9.5" shield and put the curve only in the top 50% of the mass, I think they'd have a winner...
All THAT said: I'd imagine that if you're looking for a tall, CLEAR shield, a 12" Clearview recurve would probably be the ultimate.
Old 06-01-2009, 07:57 PM
hotshot's Avatar
hotshot
hotshot is offline
I have the Clark's, 10" Half Moon, would never go back to stock.
Old 06-01-2009, 08:01 PM
Hog Yild's Avatar
Hog Yild
Hog Yild is offline
Again, this company makes a very good product for the price they charge!
No, I'm not associated with them, just a happy customer.
Old 06-01-2009, 09:05 PM
Mike5959's Avatar
Mike5959
Mike5959 is offline
so does the fork baffle really work? Anyone got a part number on a black one and a pic of it installed?
Old 06-01-2009, 09:58 PM
acchd's Avatar
acchd
acchd is offline
No pic but black baffle is pn 58520-79B and runs ~$12.50. Chrome one is pn 58520-79TC and ~$25.
Old 06-01-2009, 11:11 PM
sonar_chris's Avatar
sonar_chris
sonar_chris is offline
The fork air baffle is standard on Road Glides. They work really well as I get no air from between my faring and my forks. I have no problems with heat because of it and leave it on all the time.
Old 06-02-2009, 12:48 AM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
The HD fork baffle is cheap enough and actually looks good on the bike but I really can't tell much, if any, difference in air flow on my RK Custom. I leave it on year round.
Old 06-02-2009, 07:15 PM
Hog Yild's Avatar
Hog Yild
Hog Yild is offline
You are kidding right? You don't have a fairing or windshield on your bike in the picture.
Old 06-02-2009, 08:45 PM
GliderXXX's Avatar
GliderXXX
GliderXXX is offline
In order of the most effective ways to decrease wind turbulence:
1-Lower Fairings. The ride with them on and off is night and day. MOST of the wind that is bothering you is blocked. I personally think they look great on SG's.
2-6" or taller windshield. A lot is what you get used to. Anything 7" or higher will help, with and depending on your height, 9" is a good compromise for style points and comfort. The Cee Baileys SSC 12" will almost eliminate buffetting, and the 13" just about does eliminate it. I'm used to my 6" or 6.5 Clearview w/recurve for just about any distance or condition.
3-Fairing wings. I like the HD ones. They are adjustable and fit perfectly. Higher quality than the Freedom Wings etc.
4-The upside down ash tray between the forks that is standard on Road Glides.
Lower fairings are however, far and away, the best way to improve the turbulence.
harley0711's Avatar
harley0711
harley0711 is offline
How about the little 'wings' that attach to both lower sides of the fairing??
Quick Reply: Where is all the turbulence coming from?
