accessory plug
Old 05-30-2009, 06:51 PM
jackinthebox's Avatar
jackinthebox
jackinthebox is offline
Default accessory plug
Im trying to wire my amp to the accessory switch so I can turn it on and off. I found the plug with the big rubber boot that I believe is it. My question is the some kind of adapter I have to buy to wire to it. I just need to connect one wire to it.
Thannks.
Old 05-30-2009, 07:15 PM
MickeyB's Avatar
MickeyB
MickeyB is offline
If you want the plug, I used HD p/n 91843-97 Supplemental 12v power point in the '09 Harley catalog page 479. I used this to power my GPS. It is basically the deutsch plug with the wire leads and a cigarette lighter socket. You can do away with the cigarette lighter socket and just use the deutsch plug and wire lead. Kinda expensive though at 19.95!
Mike
Old 05-30-2009, 07:24 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
There isn't an "adapter" per se. You need the male Deutsch DT four-wire connector and a "socket" (for your wire end) to go into the connector so the connector will mate with the accessory connector ("plug"). The HD accessory mentioned in the previous post has the connector and socket already assembled.
You aren't going to wire the amp's main power to that accessory connector are you? High amperage accessories (such as fog lamps, etc.) are wired directly to the battery with that circuit controlled by a relay that is controlled by a lower amperage switch (in this case the accessory switch).
Old 05-30-2009, 07:33 PM
onthelo's Avatar
onthelo
onthelo is offline
If you dont want to use that adapter plug/fitting you could just t-tap the wire although i would use the connector to keep the wires clean.
Old 05-30-2009, 11:24 PM
jackinthebox
No am wiring the man power to battery just need the switch on to the accessory.
So the part # listed above will work or do I need something else.
Thanks
PaGuy610
07-30-2018 11:32 AM
wombat457
08-14-2015 03:43 PM
Razir66
09-03-2014 03:49 PM
semelsje
Electrical/Lighting/Alarm
04-20-2014 05:07 AM
jackod
02-11-2013 09:01 AM
Quick Reply: accessory plug
