Monster ovals, PCV and SE Ventalator
todave i did my first service, amsoil 20w50 in all holes. put on monster ovals, screamin eagle ventalator ac and a pcv mapped for above from fuel moto. took about 5 hours to do it.
all the installs went well, no problems. the monster ovals are awesome, look great and sound perfect, exactly what i was looking for.....deep not too loud.
the bike runs great, pulls stronger no popping or backfiring. it takes much longer to activate the heat management system but..... now when it does, it stalls as soon as i apply throttle, perhaps an indication that the map from fuel moto isn't perfect? i had planned to not bother with dyno tuning if everything felt perfect but i guess i'm gonna have it tuned.
any way here's some pix....
oh ya, well i was there i put some silcone in the front swing arm hole and drilled out a hole in the guard to allow moister to escape. i do ride in the rain and there was rust showing already.....
I have a PCV and map from FM, I noticed mine has a hesitation when you take off while it is in the one cylinder mode. I also have the auto tune module and it works great. I believe the hesitation or stalling that you are feeling is something to do with the PCV, I had a fuel moto map which I was happy with, but the auto tune tweaked it in even better.
I wouldn't bother doing a dyno tune and I am pretty sure it won't do anything for the stalling when in cylinder deactivation mode. Perhaps there will be a update to the firmware of the PCV to help this problem. I haven't talked to Fuel Moto about it, I can use it, but I don't like the way it hesitates. It didn't do that before the PCV.
So I tried to set the throttle (out of curiosity) and found that I cannot adjust anything while the bike is not running. So the bike needs to be running which means there is no way to get the upper throttle measurement unless you turn your throttle all the way and then your bike is doing 7000 RPM.
I'm too stupid to figure it out so I left it alone.
lp
Dave,
This is a PCV issue dealing with the settings the ECM provides for the heat management mode.....and coming out of it. It is common to sputter and hesitate, athough you prolly have one of the more tempermental ones. You'll notice if you disconnect the PCV the problem is gone. I suspect Jamie is on it.
Kenny
Kenny
