Royal Purple stinks!
Old 05-29-2009 | 08:28 AM
eja's Avatar
eja
Default Royal Purple stinks!
I just changed my oil over to Royal Purple and according to my thighmometer my engine seems to be alot cooler. But now when i decel or stop I can smell the oil and it really stinks! Double checked the level both hot and cold. Any ideas or suggestions. Any body else notice this?
Old 05-29-2009 | 08:36 AM
bagman1's Avatar
bagman1
You may be burning it, and thats why you can smell it coming out the exhaust.
Old 05-29-2009 | 08:39 AM
dnewman007's Avatar
dnewman007
You are probably smelling the oil carryover into the air cleaner.
Old 05-29-2009 | 09:10 AM
Mathews2's Avatar
Mathews2
This is my guess, I changed to redline once and had to run it slightly lower than full to stop it from puking through the breather, but amsoil I could fill and not have the smell, dont know why, but really like the redline or the amsoil. I am very fond of the redline shockproof heavy in the tranny.
anyone else think the Royal purple is helping them run cooler, I am for anything to reduce the temps.
Old 05-29-2009 | 09:50 AM
gmc's Avatar
gmc
Royal Purple doesn't test as well as Amsoil, Mobile 1, Redline according to what I've read. I just switched to Amsoil fr HD 360 and so far really like it but hard to find so may end up w Mobile I. I also like the Redline Shockproof for tranny and their Primary oil, which helps w the clutch pull and heat, pricey but last longer.
Old 05-29-2009 | 10:26 AM
skratch's Avatar
skratch
well of course not, if you've read the amsoil white paper. you know they are not gonna put out any literature that says that their oil is just as good as any other oil out there.
course, if you believe everything that you read, there are pills out there to make your d*ck bigger, make you skinny, make you a mensa candidate, and irresistable to the women. hmm, then why do i see so many bald, ugly, guys running around (not gonna comment on d*ck size, don't wanna know) by themselves?
in truly independent testing, amsoil is a good oil. is it better than any other? in some areas yes, but in some areas no. truth is, there is no one 'best' oil. run what you like, that you can get a hold of easily, and change it according to manufacturers recommendations. you'll be good then.
http://home.earthlink.net/~skratches...motorcycle.pdf
Old 05-29-2009 | 10:35 AM
Coloradodude's Avatar
Coloradodude
I have heard before that Royal Purple smells, I dont think anything is wrong with your scoot, it's the oil.
Old 05-29-2009 | 10:51 AM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
That's the smell of lubrication I use RP
Old 05-29-2009 | 10:54 AM
Frankie-FLHXI's Avatar
Frankie-FLHXI
oh great an oil thread
Old 05-29-2009 | 11:00 AM
Phurion's Avatar
Phurion
oh great, someone who lacks enough self control to not click the link clearly titled as an oil related post.
/facepalm
No one made you click it.
Quick Reply: Royal Purple stinks!
