speed-o problem
speed-o problem
What a day to ride. I made a stop in at the dealer this morning and hit the road, did a
real nice 200 mile scoot-a-bout. As I neared home this evening the speed-o needle just
dropped to zero like a rock and the gauge lite went out. It stayed this way for a few
seconds and then popped back up. A minute later it did it agian, but this time it stayed
out for quite sometime. I've never seen this happen before, could it be a senor issue, is
there a sensor? Anyone have this happen or know the workings of a speed-o on a 2002
FLHTCUI ?
I have no shop book on this bike. I guess after 4 yrs and 41k miles I better buy one. ; )
Thanks all,
FLHTCUI ?
Thanks all,
RE: speed-o problem
I don't know about the gauge light going out, but the seedo sensor is on the top of your transmission. It's held on with a single screw. Remove this and pull the sensor up and clean the metal shavings off of it. Re-install and you're done. Usually when this is the problem, the speedo needle hops around alot. This may not be your problem though, due to the light going off to.
[IMG]local://upfiles/8977/BB79D38D53B24FFBB1D7E9E0EA3B1D92.jpg[/IMG]
RE: speed-o problem
If the light is going out then your gauge must have loose wiring or maybe a cold solder joint internal to the unit...regardless I'd bet the problem is "power" related and not a sensor. A sensor does not backlight the gauge know what I mean? Try opening up the bezel and reseat everything first...
ORIGINAL: nowhereman
Great, I'll be checking the sensor tonight.
I'm hoping for an easy fix, yeah right.
I have a memorial weekend trip planned,
so of course something has to flair up.
thanks for your post.
RE: speed-o problem
Thx for advice all.
I did pull what I thought to be the sensor from the top of the trany.
This sensor has a spring pressured ball in it. I found no filings at all.
I did blow it out good with air and wiped it down good. Put it back in
and the problem still there. You're probably right, it's a pwr issue. I'll
pull the fairing and look for loose wires/ground.
RE: speed-o problem
hmmm, I may have removed the wrong sensor, I think I pulled the sending unit.
The unit I pulled had two wires and was a screw in type of device that takes about
an 3/4 wrench. I read more post and it seems like the speedo sensor unit is held in
place by a allen set screw and has one wire. ??? I'll search the www for a picture.
If anyone has a pic ( of the sensor ) they can post that would be great!
Thanks again all,
Thanks again all,
RE: speed-o problem
Went out on lunch break and found the right sensor. Looked down and there it was, duh...
Removed it and was cluttered up pretty good. A short ride around the parking lot and it looks
good so far, I'll get it on the road after work to make sure.
Thanks again for the advice.
