ABS Software update
Old 05-27-2009 | 07:36 PM
Ace07FXDL's Avatar
Ace07FXDL
Originally Posted by cosshog
It should not but make sure with the tech knows this before hand because if it ask him to reflash the system and he does then the program is gone. Can you copy the program in it now to a disk? If so do so just in case. Also where was the dyno done? Do they keep the map? and if so ask them for a copy so you have it just in case anything ever happens to your ecm and you need to reprogram it. Dyno maps that you pay for should be stored in there system or ask them for a copy of the map.
Thanks for the info. I do have a copy of the map and I can reload it if I have to. I will let the tech know ahead of time that I'm running a non-stock map. Thanks again!
Old 05-27-2009 | 11:31 PM
LUBA's Avatar
LUBA
Let me know how that works out for you Ace. I also have a TTS map on my bike and want to know if that will effect this ABS update at all.
Old 05-28-2009 | 06:08 AM
XTrooper3936's Avatar
XTrooper3936
Originally Posted by Ace07FXDL
Will this update affect the tuned map I'm running now after a dyno tune using my SERT Pro?
Absolutely not. It will only change the ABS parameters of your ECM programming.
Old 05-28-2009 | 09:21 AM
LUBA's Avatar
LUBA
Would this also be the same for one running a TTS map like me?
frank zinna
01-07-2019 09:22 PM
NakedShayne
05-20-2017 10:08 PM
sgdiesel
05-24-2009 03:31 AM
HDBulldog
11-19-2008 12:50 PM
casique
02-07-2008 07:44 AM
Quick Reply: ABS Software update
