Police tire question
Bought a new '09 EG Police bike that I'm going to convert to a 2-up touring bike. A sticker on my rear fender says "Tires rated for one person. If motorcycle is changed to carry two people, tires must be changed." It says serious injury or death may occur...
What's up with that??? Is it something about the "run-flat" tires?? Would I have to change just the rear tire, or both??
Thanks
Thanks
if you go to a harley dealer and look at all the numbers, sizes etc, information about the tires that's printed on the sidewall, on a bike in the showroom and the numbers are the same as the numbers on yours, then i'd think theyr'e the same tires. if you know of a place where cop bikes are used, then check with that dealer who services their bikes, they'd have all the information on them. in tulsa it's meyer durham hd. they service the cop bikes for tulsa.
Disclosed is a run flat tire for motorcycles having a high handling stability, cornering stability and durability even when the tire is punctured during running and the pneumatic pressure inside of the tire becomes equal to atmospheric pressure. The run flat tire has a pair of sidewall-reinforcing layers each comprising (1) an elastic filler extending from an end location adjacent a bead core in a bead portion to the other end location in a tread portion through a sidewall portion of the tire and (2) at least one reinforcing ply which extends along one side surface of the elastic filler toward the tread portion, is turned up around the end of the elastic filler in the tread portion and which then further extends along the other side surface of the elastic filler toward the bead portion.
Run flat tire info. --- http://www.freepatentsonline.com/4202393.html
Run flats are not designed to be ridden 2 UP WHEN FLAT. That's why they are not on civilian bikes.
