Notices
Gear drive issues???
Old 07-09-2009, 10:06 PM
OG1's Avatar
OG1
OG1 is offline
was there ever any resolution on this? did you go back to chains?
Old 07-10-2009, 01:42 AM
emwolb's Avatar
emwolb
emwolb is offline
hope you get it figured out. keep us posted when you get it working right. many end up using the harley later type chain drive cam plate and oil pump. it sux to end up doing stuff twice, and is expensive. i feel your pain man.
Old 07-10-2009, 05:38 AM
HD Renegade's Avatar
HD Renegade
HD Renegade is offline
This is interesting for sure. Gear drive going into my 06 in the next few days.
Old 07-10-2009, 08:46 AM
Egldr05's Avatar
Egldr05
Egldr05 is offline
If it were me I'd go with the new style chains/tensioners, much less chance of having any issues with crank runout. It wasn't available when I did my build the first time or that's what I would have done. That's the way I went on my friends 00 RK when I did his Andrews 37/AMS 96" motor. He couldn't be happier.
Rick
Old 07-10-2009, 09:09 AM
skydoc's Avatar
skydoc
skydoc is offline
* [1] Get the rear tire off the ground and the transmission in 5th gear. Install the two intake pushrods only. Do NOT extend them.
* [2] While holding the front intake pushrod against the lifter, roll the engine until the front intake pushrod is as high as it will go. This will insure that the front intake is full open on the camshaft, and the rear is fully down on the camshaft.
* [3] Adjust the rear intake pushrod and wait 15 minutes. Then make sure you can roll the rear intake pushrod but there is no up and down play.
* [4] While holding the rear intake pushrod roll the engine until the rear intake pushrod is all the way up. The rear intake valve is now full open and the front is fully closed.
* [5] Adjust the front intake pushrod and wait 15 minutes. Then make sure you can roll the front intake pushrod but there is no up and down play.
* [6] Install the two exhaust pushrods. Do NOT extend them.
* [7] While holding the front exhaust pushrod against the lifter, roll the engine until the front exhaust pushrod is as high as it will go. This will insure that the front exhaust is full open on the camshaft and the rear is fully closed.
* [8] Adjust the rear exhaust pushrod and wait 15 minutes. Then make sure you can roll the rear exhaust pushrod but there is no up and down play.
* [9] While holding the rear exhaust pushrod roll the engine until the rear exhaust pushrod is all the way up. The rear exhaust valve is now full open and the front is fully closed.
* [10] Adjust the front exhaust pushrod and wait 15 minutes. Then make sure you can roll the front exhaust pushrod but there is no up and down play.
Old 07-10-2009, 09:37 AM
Hammy's Avatar
Hammy
Hammy is offline
I have S&S 510 gear cams and stock cam plate, have no noise on lower end but once engine is hot it is noisy up top that's normal. Especially if you are running synthetic oil. Synth makes more valve noise, I wouldn't worry about it shouldn't be any issues. If you want to quiet it down run dino oil or add a thickener like Lucas or Moly or motor honey or STP.. Can't go over 10-15% additive as you may get clutch slippage..
Old 07-10-2009, 10:10 AM
Neil's Avatar
Neil
Neil is offline
I got things to get quite finally. I had to put the stock cams and chain drive back in. Things are now quite as a mouse. After all of the solutions I tried to quite it down the engine is quieter now than before I tore it apart. I did try the oversized pinion gear and it didn't do what I needed. After getting so fed up I put the stock tensioner set up back in on the SE billet cam plate and bolted the stock cams back in. I am glad to be riding again.
I miss the power the HQ cams gave, but, I have had suggestions that they could have been the source of the noise. I hope not, but I don't think I will bother to tear into it again until I need to check the spring loaded tensioners.
Thanks to all that have offered suggestions and support!!
Neil
RDMC
Old 07-10-2009, 10:28 AM
iclick's Avatar
iclick
iclick is offline
Originally Posted by FXDIinMD
+1... don't know anything about this "Baisley spring"... my gear drive and Andrews 37g cams gets to clackin' when it get's hot... Mobil 1 helped quite it down but Amsoil and Redline are very noisey!!!! 33k miles on my cams and gear drive and it runs great!!
A friend with a BMW GS (boxer engine) told me that Mobil 1 was noisy in his bike but Royal Purple 20w50 quietened it down considerably. You might give it a try, available in this area at Napa, Pep Boys, and most speed shops.
Old 07-10-2009, 11:01 AM
HD Renegade
Rick
Hmmm, but if you are also putting in a brand new stroker crank, then I really should not have to wrroy about the run-out should I ???
Old 07-10-2009, 12:16 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
If it's a stock HD crank runout could still very well be a problem. I would sure check it and not assume anything. Gears don't like more than .002 and stock cranks have been known to be further out than that especially some of the newer ones.
Rick
remmag
Exhaust System Topics
07-16-2011 04:17 PM
SubZer0
06-22-2008 07:36 AM
SmokinEd
06-01-2008 10:07 PM
wrustywrench
04-18-2008 06:05 AM
fiddledicksr
16
01-09-2007 08:26 PM
Quick Reply: Gear drive issues???
