Can new rear tire put speedo off?
Old 05-25-2009 | 08:01 PM
vinnieee's Avatar
vinnieee
Default Can new rear tire put speedo off?
Installed a new rear tire Friday (Dunlup Elite 3 160/80B16 80H), but now state trooper told me my speedo is off by giving me a speeding ticket (I said 62 he said 72). How do I correct this problem? Can I correct the tire size with the SERT, or do I need Harley dealer do this?
Thanks for any help or suggestions in advance. Vinny
Old 05-25-2009 | 08:15 PM
Lucky 13's Avatar
Lucky 13
Changing to a larger diameter tire will make your speed read slower than you are actually going but 10 MPH at 62? The cop needs to get his Radar gun calibrated.
Old 05-25-2009 | 08:20 PM
vinnieee's Avatar
vinnieee
That's what I was thinking, but I just installed my birthday present, so I just wanted to get back on the road and ride. Later that day I went by one of those signs that gives you your speed and it said 49 and the speedo was at 42 - that's 7mph difference.
Old 05-25-2009 | 08:25 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
thats about right bigger dia tire will travel farther per rpm= faster than speedo reads, mine is off almost that much stock get a gps and youll find most harley speedos off by about 5 %. dont know if sest can calibrate it but thundermax does have that feature.
Old 05-25-2009 | 08:41 PM
Wassup8687's Avatar
Wassup8687
Check it with a GPS. If you don't have one borrow a friends. You'll get your true speed.
Old 05-25-2009 | 08:48 PM
ko4qc's Avatar
ko4qc
Check your speed with a GPS before paying ticket/going to court....most Motorcycle/Automobile/Boat speedometers are notoriously inaccurate...BUT usually not by 10 MPH and most read faster rather than slower...good luck in court
Old 05-25-2009 | 08:52 PM
ko4qc's Avatar
ko4qc
Talking
Originally Posted by vinnieee
That's what I was thinking, but I just installed my birthday present, so I just wanted to get back on the road and ride. Later that day I went by and it said 49 and the speedo was at 42 - that's 7mph difference.
So,who says the "one of those signs that gives you your speed" was accurate?...:>)
Old 05-25-2009 | 10:27 PM
asm481's Avatar
asm481
Speedo inaccuracy would be expressed as a percentage. So 7 off at 42 could easily be 10 off at 62. Most stock set ups run a bit off, showing higher speed then you are travelling. All this said I would take it to court. State your case respectfully and they should give you some slack unless you have a record a mile long!
On another thought if say the posted limit was 55 you are screwed by your own admission that you were doing 62.
Old 05-26-2009 | 08:01 AM
huffhuff's Avatar
huffhuff
Tennesse trooper told me that if i could prove my speedo was off that the judge would be lenient. it was a 4 hour drive back to the court so it was more economical to pay it than explain it.
Old 05-26-2009 | 08:48 AM
XTrooper3936's Avatar
XTrooper3936
They do. At the beginning and end of every shift.
Quick Reply: Can new rear tire put speedo off?
