Removable Mutazu Trunk on Street Glide
Old 05-25-2009 | 07:36 PM
bdavis's Avatar
bdavis
Default Removable Mutazu Trunk on Street Glide
I barely ever need a trunk, so I went the cheap route and bought a Mutazu color-matched trunk and bought the removable solo rack off Ebay for pretty cheap. About $300 for everything. The quality is about what I expected -- not fantastic, but not horrible either. The color matching is good, although there are a couple of rough spots in the paint if you look close enough. I had to remove the bottom back rest pad to be able to move this up close enough. All in all, I'm pretty pleased with the results, although if I used a trunk all the time, I would definitely buy the HD one.
Old 05-25-2009 | 08:03 PM
Harleypingman's Avatar
Harleypingman
I've had the same set-up for about 3 years; would never call it "cheap;" instead, "great value."
You'll probably use it for trips to the store, etc., when you didn't have the storage capacity before. It weighs so little it's very easy to ****** it in one hand, put it on the bike, run your errands, and put it away when you're back home.
Looks good, and you have about $650 left to spend on other bling for the bike.
The box's construction is very similar to that of the tour pak HD offers for Road Kings. Just another reason I don't refer to the Mutazu box as "cheap."
Old 05-25-2009 | 08:28 PM
dredy2g's Avatar
dredy2g
thats the same tour pak that i have just needs some paint
Old 05-25-2009 | 08:37 PM
overhead's Avatar
overhead
I have one, I would advise that you make sure the nuts on the cable that holds the lid on are tight or better yet put some lock tight on them. Both of mine rattled loose one trip. Other than that it has served its purpose, which is light use once in a while.
Old 05-25-2009 | 08:47 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
do not try and put a rack on top it will crack.
Old 05-25-2009 | 08:52 PM
overhead's Avatar
overhead
I have a rack on mine and have not had that problem.
Gooey2
Touring Parts
08-14-2016 03:04 PM
linearone
General Topics/Tech Tips
04-17-2016 05:30 PM
Q Hog
02-02-2010 02:58 PM
scottdoege
12-17-2009 08:30 AM
Kern
03-21-2007 04:07 PM
Quick Reply: Removable Mutazu Trunk on Street Glide
