Zumo 550 on Electra Glide Sandard
I have an 09 Electra Glide Standard (no radio). I'm wanting to install a Zumo 550 and run it to an amp and out to speakers in the fairing. Wiring the amp to the speakers is no problem, but do I need any other device or cable to wire the Zumo to the amp and have stereo sound? Also wondering if there is a way to control the audio on the Zumo with the audio controls that are factory installed on the bike? Thank you for any info you can give me. BT
Check out cyclegadgets.com. I purchased the premade harness kit that allows for connection through the AUX port. They also have another harness that allows you to replace a couple of wires in the bike's radio wire harness. I have all stereo sound for the XM radio and mp3 installed with the Zumo 550
Here's pic of my installation
http://s451.photobucket.com/albums/q...t=DSCF0536.jpg
BT,
I have a zumo 550 installed on my Ultra Classic. First and foremost I would say check out zumoforums.com They are the experts over there. To answer your second question first there is no way that I am aware of to control the audio of the zumo with the controls of the bike. To answer your first question which I am kinda unclear what you want to do. The zumo cradle has to be used and the only plug on it is a 3.5 audio out jack that you need to plug into a aux port or one on the amp if it has it.
immusicman
Screamin Eagle CVO Models
10-02-2014 06:45 PM
tuckertaft
06-15-2010 08:13 PM
