tru dual rattle
Old 05-23-2009 | 08:30 PM
hammer1's Avatar
hammer1
Default tru dual rattle
have a 05 road king that i installed vance and hines tru duals on and am getting a annoying rattle when the bike is idling. cant seem to pinpoint the location, anyone else had this problem and any suggestions on a fix.
thanks,
Old 05-23-2009 | 08:48 PM
PSO169's Avatar
PSO169
Default Dresser Duals noise
I have the Dresser Duals on my Ultra Classic. I get a noise ever once in awile. I noticed that it is my Inspection plate for my state inspection sticker that is mounted close to the slip ons. I have to check it ever now and then. It ends up making noise and I have to tighten it. Just a thought other than that no issues with the duals. Hope it helps.
Jeff
Old 05-23-2009 | 11:01 PM
Yachtman's Avatar
Yachtman
If they're new, return them. I had the same baffle rattle with my new Rinehart TDs and they replaced both mufflers, including shipping. Sent me out a new set and I returned the mufflers in the same box.
Old 05-23-2009 | 11:51 PM
roadglider1's Avatar
roadglider1
Look to see if you have a crack in the left side pipe support bracket above the tranny. Also check the rubber isolators at the end of the mufflers. I have had both fail on my 04 which allows excessive vibration. Hope this helps
Old 05-24-2009 | 12:01 AM
xxxflhrci's Avatar
xxxflhrci
The pipe is so close to the side cover on the left of my bike that you can't get the cover off without unbolting the muffler and pulling the pipe away from the bike. On acceleration, the pipe hit the cover. No amount of readjusting fixed it. I finally put a felt pad between the pipe and cover. Never heard it again.
Old 05-24-2009 | 03:14 AM
GMONEY220's Avatar
GMONEY220
Default Rattle
Make sure the bracket by the starter is secure!
Old 05-24-2009 | 05:50 AM
Anthony8858's Avatar
Anthony8858
I have TD on my 2005 RKC.
The sound you describe could be caused by having a loose heat shield somewhere along the pipe. There are adjustable clamps all along the back of heat shields. Give me all a good turn with a screwdriver.
Old 05-24-2009 | 08:37 AM
BillyG0856's Avatar
BillyG0856
The left side on my stock pipes makes a squeaking sound @ idle. Im thinking it's the isolater.
HOGNIT
07-02-2015 10:34 PM
1Digger
07-24-2013 08:41 PM
Tanker2
07-25-2012 03:06 PM
fenderzig
12-03-2011 04:17 PM
HilllBillly
06-19-2007 01:28 PM
Quick Reply: tru dual rattle
