Fork Oil Weight
Old 05-22-2009 | 07:21 PM
gabulldog's Avatar
gabulldog
Default Fork Oil Weight
Guys, I'm finally starting to re-assemble my bike after months of work, chrome, extending the bags, tank, etc. I have read every thread I could find about forks / race tech / progressive / etc. I am using the Race Tech kit, 1" spacers. What weight oil are you guys using? I see 10-15-20 wt. It seems as many guys as you ask you get that many different answers. Also, HD has been using this same fork set-up for years, why can't they tell you how much oil to put in the forks? Whats up with his measuring deal, every bike I've ever had ie: Ducati, Honda, etc. gave you the amount needed. Thansk in advance for your help. gary
Old 05-22-2009 | 07:22 PM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
My manual says how much oil to use. I used the middle grade 15 last time I changed oil. Made the front a bit stiffer.
__________________
Old 05-22-2009 | 07:49 PM
dawg's Avatar
dawg
10.8 oz for tourers except FLHR's which is 11.1 oz. I use the equivalent to about 15w. I mixed HD type E with SE Heavy
Old 05-22-2009 | 08:41 PM
Beemervet's Avatar
Beemervet
I mixed 10W and 15W............ I think I like it.
Old 05-22-2009 | 09:51 PM
xxxflhrci's Avatar
xxxflhrci
After dinging my front fender on the brake tee during a hard stop/pot hole combo at just the right time, I swapped to SE Heavy. It stiffened the front end up nicely.
Old 05-22-2009 | 10:02 PM
hogbag07's Avatar
hogbag07
I'm using 10 weight Castrol fork oil with progressive springs its a nice ride with no diving under brakes your going to love the difference they make in corners. I think I cut my spacers 1 3/4 inches long from memory
Old 05-22-2009 | 10:06 PM
BadPiggy's Avatar
BadPiggy
I run 5wt. Amsoil Fork Oil.
You can easily & cheaply make a measuring gauge.
Believe it or not...
One of those fried turkey injectors...a length of hose to fit the injector....a metal tube...a ferrule.
Everything except the injector can be bought at a hobby shop.
Old 05-22-2009 | 10:12 PM
t150vej's Avatar
t150vej
Yea, I went with 30w once geeeeez. Rode like a wagon. 5w or 10w at the most for me. Air ride is good with ATF in fact.
ghoulardo
2014-2023 Touring Models
03-23-2018 07:17 AM
dennyo
12-30-2013 07:48 PM
kjkustoms
06-25-2012 09:21 AM
shrini23
03-31-2012 09:14 AM
Naz_Man
03-08-2009 11:40 AM
Quick Reply: Fork Oil Weight
