im putting a 120/70/21 tire up front with a hugger fender but im keeping the 16'' rear for now how much do i need to lower the front.. how much can i go.
some will say you MUST lower it or the handling will suffer. I didnt lower mine and cant tell a difference. id rather not lose the ground clearance and worry about my fender hitting the frame, so i am leaving it up. i also have 11.5 rear shocks, so am lowered 1.5 in the rear.
With that size tire it will def. rake the bike up and already if your on a flhtc you prolly got a 13" rear shock so that bike will be sitting up high def. lifted in the front. I would go 1.5" lower in the front forks. I ran the 1.5" drop in the front and the 12" shock in the rear and it still has a very slight rake but very good hanbles great and my front fender still has good ground clearance its more of a comfort issue on the lowering i think. Good luck take some pics when finished.
