Guys With White Walls...??
Old 05-22-2009 | 10:33 AM
jorswift's Avatar
jorswift
Default Guys With White Walls...??
I have a concern about having white wall tires. I have them and live in the country with hard water. My white walls are starting to not be so white. How do you guys/gals keep them clean and white? thanks.
Old 05-22-2009 | 10:34 AM
Beemervet's Avatar
Beemervet
A product called Bleche White. Or blackwalls and forget it.
Old 05-22-2009 | 10:37 AM
Toypuller's Avatar
Toypuller
Mr. Clean magic eraser.
Old 05-22-2009 | 11:31 AM
JonnyD's Avatar
JonnyD
Use an SOS pad and rinse em off. It's easier if you have a jack. Tires look brand new all the time and no harsh chemicals. Try it you'll be amazed.
Old 05-22-2009 | 11:38 AM
Road Ranger's Avatar
Road Ranger
I don't have www but +1 on the bleche white
Old 05-22-2009 | 11:57 AM
stro1965's Avatar
stro1965
I have that bleche white stuff but rarely need it. Soap and water and a scotchbrite pad do the trick in a couple of minutes for me.
Old 05-22-2009 | 11:59 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Sponsor
I use Shout! laundry stain remover. Works like a charm. $2 a bottle. Wet tires, spray and scrub with a brush, rinse off. Sometimes www's discolor due to sun, age, etc.
__________________
Old 05-22-2009 | 12:38 PM
TNTHarley's Avatar
TNTHarley
+1 on the Mr. Clean Magic Eraser !
Old 05-22-2009 | 12:47 PM
fatbob's Avatar
fatbob
+2 on the Mr. Clean Pads
Old 05-22-2009 | 01:06 PM
ky_ace's Avatar
ky_ace
I've used the Mr. Clean magic eraser, Westley's White-wall bleache, SOS pads, and Simple Green. If I let them go very long, I'll shoot them with Westeys. The only issue with that is it will require a little work to get it off the rims. If you use an SOS pad, the blue stuff just washes right off the tires and wheels. The magic eraser works well but does "lint" quite a bit. I'd go with SOS pad, much less scrubbing
Quick Reply: Guys With White Walls...??
